I have a 2000 60HP. Was getting the boat ready for spring use and noticed the engine tilt was "sinking", not holding.
I opened the tilt chamber to check the fluid level...it was fine, so I hand screwed the plug about 1/2 way...and then tighten the a socket...but the plug didn't tighten..it just spins. Won't tighten but won't unscrew back out. Since it doesn't tighten..fluid comes out now.
Can really use some helpful advise here. Did I screw the pooch here, or can someone walk me how to get the plug out. If I get the plug out, will a new plug solve the problem?
I know its my first post, but could you your help...thanks in advance.
