I'm installing a Yamaha MAR-WPRES-AD-TR water pressure adapter on my 2005 F60TL which will be hooked up to a Teleflex WP gauge. I've read in another thread that I should use the tubing supplied with the Teleflex gauge.
Dealer mechanic told me to replace the water jacket bolt with the red washer. Only problem is that there are two bolts right next to each other both with red washers (see bottom of attached photo to right of oil filter). Question is which one or does it matter? One bolt is angled toward the front of the engine and the other bolt inserts perpendicular to the keel. Thanks for sharing your knowledge.
