Fuel in engine oil
  • Fuel in engine oil
    I have twin 115 hp 4 stroke, model year 2000 and I am seeing approximately 1/2 pint of fuel in the engine oil every time I change the oil. The engines only have 400 hours. Has anyone experienced this problem and what was the correction? Engine seems to run fine.
    Thanks for the help.
    Have compression and leak down test run. It should be propped to turn close to 6000 rpm's. Check fuel pump and fuel system.
