Yamaha HPDI 300
  • Yamaha HPDI 300
    I have twin 2005 300, the engine on the port side runs beautiful, the engine on starboard some time pick up slowly. Whene I rev up on the port side it respondes very strong, but, whene I do the same on the starboard some times it does good and some times wont go over 2200RPMs. I've perfomed a vacuum test on the gas and it is up to standards. I have check the control cables and boxes on both the tower and the bottom and they are fine. The trottles open all the way on both situations. If any Tech out there has an oppinion will be great to listen to it.
    Thank You.
    Have a dealer check the shift switches and Throttle position sensor settings
