I have cleaned and cleared the tube from just below the plastic tube mount at the top of the lower unit and have cleaned the hole on the leading edge, but still cannot get an open passage between the two.
The hole and upper plastic tube were clogged with sandy crap which was pretty hardened, so I presume I have to get to the passage between the two openings somehow.
I have already tried to feed a wire through it to no avail. Looks like if I remove the gear shift shaft (?) I might be able to get at it.
Can anyone tell me how I gain access to the passage? And if I am to remove that gear shift shaft cover, what should I know or watch out for?
Thanks.
Dave
Thanks.
Dave
