Remote oil tank...
  • Remote oil tank...
    I recently purchased a 94 V4 115 that has the oil injection removed by the PO. I am curious, should I leave as is and premix or buy every thing and re-install? I don't mind the oil injection, almost prefer it so someone doesn't have to premix in case I am not around...
    thoughts/concerns?
    I perfer the oil injection on Yamaha motors. It could get expensive to reinstall it, not knowing what they did to remove it.
      It looks like all components have been removed from the engine itself...not sure what all should be there but the port side is void of anything I think would be related to the oil injection.
      Would this have been a remote mounted set up or smaller bottle located on the motor itself?
        You would everything listed in diagram except for number 26,27 and 28 in diagram.
        Yamaha Outboard Parts 1994 115TLRS OIL PUMP Diagram
        You would need number 23-35 and 38-41 in diagram.
        Yamaha Outboard Parts 1994 115TLRS OIL TANK Diagram
        The remote oil tank you get complete by ordering part number 6YR-W0035-92-00 2.8 Gallon Oil Tank
