I have an 89 pro v 150. I'm woundering how far to adjust my throtle. When at full throttle the linkage that rides on the accel. cam can move about 1/16" further until it fully stops. Is this to far or not far enough? It was moving about 3/16" until I replaced a roller that was wore out. There is an ajustment for this on the middle carb. Also I have slowly lost about 300-400 RPM befor this repair and was hoping this will give me some of that back. Thank you for any help.
89 pro v 150
You need to follow the sync and link steps in service manual, be careful not to change timing without the specs.
Thank you for the reply, but I don't see how this can change the timing. All this does is adjusts how far all the carbs and the oil valve open. I did not change any idividual linkage or the timing. Nothing bottoms out after I changed the roller it just opened everything up a little more(1/8 to 3/16 of an inch at full throttle). I think it is ok but was just wanted to make sure. I did put it on muffs today and it started right up and seemed to run like it always did. I just didn't want to over stroke anything at full throttle. If I'm not right please tell me. I'm not a boat mech.. I am however very capable of some repairs.
ÂÂÂÂÂÂÂÂ
