Water in oil
  • Water in oil
    Hi,
    my seperate 2 stroke oil tank has a whisp of white in it which I suspect to be the presence of moisture.
    There is about 3/4 of a gallon. Do I try remove the moisture and if so how? Or do I turf the oil? Does this affect the mix ratio etc.
    Cheers
    Andrew
    rid of the oil and clean the tank, lines, main tank
      Thanks for that.
