I believe there are more than 1 coupler for this engine. One of the couplers comes with a fuse, is the fuse needed with all of these couplers? The other non-fused couplers are different lengths, do they come with battery lugs attached? Thanks, Lou
F225 Isolator charging coupler
Either one will work, you should put a fuse inline. Yes they do have battery terminal.
MAR-69JIS-0L-ED Isolator lead with 50A fuse. Connect Isolator lead to positive terminal of second battery, connect a jumper lead between negative terminal of battery 1 to negative terminal of battery 2.
ÂÂÂÂÂ
