F60TJRC Tiller to Remote conversion
  • F60TJRC Tiller to Remote conversion
    I am thinking about buying a 2004 F60TJRC (60/40 Jet Drive) with tiller steer to replace the 2004 50TLRC currently on my boat. The 50TLRC is remote steer.
    What parts would I need to convert the F60TJRC tiller to remote using the 703 controls already on my boat?
    I have a digital Tachometer part # 6Y5- 8350T- 82. Will this tach work with the F60TJRC?
    The tiller and remote control use the same shift and throttle linkage, just remove tiller and remove cable ends from cables and install them on 703 cables.
    You would need to reset the three dip switches in back of tach, set them to first two down and third to up position for F60.
      Thank you!
