I have a 04 Skeeter with a HPDI 225 on it and am having trouble after long runs in rough water. After a long hard run it starts cutting out and then dies, like it is not getting any fuel......so we open the rear hatch and pump the bulb and motor starts right back up and runs like a champ for a mile or so, then same scenario. It seems the problem only exists when running hard in rough water. I am not getting any alarms when this occurs.
Last summer/early fall I replaced the water pump and impeller, I have changed the fuel pumps, fuel filter, water separator filter, new spark plugs, poppets and have good water pressure when running down the lake. I think it could be the FUEL BULB or the GASKETS on my fuel caps? The primer bulb is not hard when this occurs and I always pump it prior to running the boat. It seems like we are losing the prime?
I have been running both tanks simultanious when this has occured. Last bass tournament we had to limp all the way in a mile or two at a time! The wind was howling and the water was rough as hell. It runs perfect in the cool morning when the water is smooth. I am running Ring Free and Yamalube. Any insight will be appreciated. Please Help!
