Vapor seporator O-ring
  • Vapor seporator O-ring
    At the top of the VS there is a tube does the O-ring go around the tube or does it get pushed to the top and stay on the end?
    Thank you for all your help. Ya'll have really saved me with all the advice.
    Which model motor do you have? Are you talking about the oring on elect. pump?
      part #29 in the diagram
      http://www.boats.net/parts/search/Ya...201/parts.html
        How to clean a vst filter
        I found the answer its in the 4th picture down it appears to go on one tube and after the other
        http://bbcboards.zeroforum.com/zerothread/66928
        Thanks for the support.
        Ya'll are the only reason why I even try to attempt to work on my motor.
