steering seized yamaha 6h3 70beto
  • steering seized yamaha 6h3 70beto
    howdy im trying to find out how the steering is put together on the motor. the cable goes to a rod that goes into a tube on the motor then a rod goes in and out on the other side that connects with an arm to the motor to turn it.im looking for diagrams or instructions on how it all works because ours has all seized up.thanks if you can help id really appreciate it.
    The steering cable shaft slides in and out of tilt tube on motor, probably need to remove steering cable from motor clean inside of tilt tube, cable and regrease.
      Hi Strapper, are you in Melbourne? I got the same motor, same steering.
        same here
        Hi, i have the same problem, i have been advised to look at a hydraulic system?
        Has anyone fixed the seized steering?
