can anyone tell me how to change lcd gauges to analog gauges on a 1990 115 etld yamaha, are the wiring harness the same or does something has to be changed or added,and if so what , and is the wire color code the same. <redwing>
115 yamaha gauges
If you use 6Y5-83540-14-00 anaolg tach without oil lights then no harness needed. If you use 6Y5-83540-05-00 analog tach with oil lights then you would need 6R3-82541-00-00 adapter harness.
http://www.boats.net/parts/search/pa...R3-82541-00-00
