I am trying to replace the guages that came with the vessel I purchased. They are original LCD guages. The original engine ( 1993 2-stroke carbuerated 200 hp) was replaced with a 2003 2 - stroke carbuerated 150 V6. What are the part numbers for new LCD guages that will replace the older versions? I ordered the 6Y5's and the harnesses dont match up( I have round pins and the 6Y5's are flat pins) and there are xtra wires. Any help ?
1993 LCD Guage replacement
You can use
6YR-W0035-E2-00 Tach kit and 6Y5-85335-10-00 adapter harness or
6YR-W0035-F2-00 Tach and Speedometer kit and 6Y5-85335-10-00 adapter harness.
The gauge kits will include wire harness needed for installation.
http://www.boats.net/parts/search/pa...Y5-85335-10-00
