Speedo, Tach & Fuel Managment Kit
  • Speedo, Tach & Fuel Managment Kit
    Hello,
    I need help about completing my new boat whit new Digital gauges. My outboard is 2008/F60 with standard equipment. The boat arrive to me only in December 2008, for this reason I cannot look into the boat but I know that the following part was included:
    - Standard control box 703 with standard harness
    - TACH Gauge with standard harness (I'don't know if it is the same harness of 703 Control Box)
    No idea of how many LAN hub there are, and also if there is one with standard yamaha outboard equipment.
    Now I need to know what articles (parts and harness) to order from boats.net to install the following parts that I already have (TACH is already included with standard equipment):
    - 6Y5-83570-S5-00 Multifunction Speedometer (SPEED) The sender unit is already included in the outboard?
    - 6Y5-W0088-53-00 Fuel Management Gauge Kit (FUEL)
    Many thanks in advance for help.
    Corrado
    To use those gauges you won't be able to use Command Link series gauges, you will need to use Yamaha Multifunction tach. Just order 6YR-W0035-E2-00 tach kit and it will have what you need.
      I have not explained well, now on my boat there are already mounted this articles:
      - Multifunction Speedometer cod. 6Y5-8350T-82-00 including harness
      - Premium 703 Side Control 703-48207-17-00 including harness
      Now I bought from a stock this other articles that I want to mount on the boat:
      What I need to buy from you to connect everything, considering that I already have some harness included with Multinfunction TACH and 703 Control Box?
      Many thanks for cooperation.
      Corrado
        Sorry on the second line I want to write:
        - Multifunction Tachometer cod. 6Y5-8350T-82-00 including harness
        Sorry for the mistake.
          If you have gauges only (speedo and fuel management) and no harness or sensors then you will need.
          6Y5-83557-10-00 speedo hose
          6Y5-83553-F1-00 sensor lead
          6Y5-85752-01-00 Fuel flow sensor
          703-82531-00-00 wire lead
          6Y5-87122-S0-00 signal lead for speedo
            The fuel management it's a complete kit 6Y5-W0088-53-00, the speedo it's only gauge, what of the articles that you've listed I need ?
            Thank you.
            Corrado
              Just the hose
