regarding my problem of my motor going into safe mode i followed boats.nets suggestion of grounding the pink wires on my thermal sensors, after grounding both sensors NO alarms went off. while i had the cowl off i removed the oil sensor on the motor and still NO alarm. two months ago i serviced the cooling system, replace water pump, replaced both thermostats and both thermal switches.
with the engine running i still don't get an rpm reading. i also noticed when i have the key in the on postion two out of the three bars are blinking and with the engine running only the first bar is blinking.
any suggestions would be greatly appreciated.
thanks, stoney
thanks, stoney
