Power Trim Tilt Tbl
  • Power Trim Tilt Tbl
    I have a 2001 F80TLRZ that is giving me tbl with the tilt trim.
    The motor will drift down and when underway I have to keep retrimming
    the motor. I have changed out both valve assemblies. Any idea's ?
    power tilt trim tbl
    The fluid level is fine and the manual valve is tight.
      Tilt Trim Tbl
      When checking the oil level should the unit be vertical and fill with oil to the top of the fill plug? or should I tilt the unit as Horiz. as possible?
        Trim & Tilt Fluid replacement question
        I have a 2000 150 Yamaha 2 stroke that needs Tilt and Trim fluid...is there a diagram with instructions that I can see to do this myself?
          use your manual release valve not motor
          release valve lower motor. lift motor.
          do this twice.
          lift motor just above where you would take your motor to put it on swing down lug.
          now fill reservoir
          put cap back on
          lower motor and raise twice
          top up fluid
          leave for an hour
          same proceecs reason why not to use motor it airrate oil
          hope this helps
