I have an 05 F40 that I would like to put a Mercury Quicksilver prop on. I got the Mercury trust washer to use with it. My question is do I need any kind of washer between the prop and the prop nut? It doesn't seem like I do but I'm just not sure. Thanks
Prop washer nut?
You will need to use Mercury lock tab washer or cotter pin which may need washer to align cotter pin hole.
Thank you. I was planning on using the cotter pin. I guess I just wasn't sure if I needed a washer between prop and prop nut as some sort of portection or seperation. Thank you
ÂÂÂÂÂÂÂÂÂÂ
