Removing Powerhead ???
  • Removing Powerhead ???
    Hello
    I have a 25 hp yamaha 1995 vintage. I have a bearing problem and need to remove the power head. I have removed all the bells and whistles, linkage, carbs,oil resevoir,etc and then removed the 6 large bolts under the powerhead. The powerhad is still very not moving. i have wrapped it lightly with a block of wood and still no movement. do i need to loosen anything below in the lower unit? the motor only has about 10 hours on it. the gear lever is in nuetral. Help??
    No it should come off may have to pry up on engine to separate.
