Hey guys,
I recently replaced water pump on my 1997 200TXRV. Next time out I noticed a rattling noise when motor was engaged into gear. I immediately returned to neutral and listened no noise. When motor was in engaged to reverse this time the same rattling noise. I then placed motor into forward, heard the noise again. I then gave the motor some throttle and noise went away. Throughout that day of fishing as long as I gave the motor a little of additional throttle once placing into gear I did not hear the rattling noise. After returning home, I pulled the lower unit and disassembled to look for problem. I could not find anything wrong with pump assembly. Reassembled and started motor on the muffs. I placed motor in gear and listened for rattling noise. It sounds like its being generated in the mid section of motor. Anyone help with diagnosis would be greatly appreciated.
Thanks for your help in advance.
Hillfisher
Hillfisher
