All,
This is a low hours 92TXRQ. I have rebuilt all 6 carbs, replaced the three pulse fuel pumps, no anti-syphon valve in main tank. Have hooked up an auxillary tank and symptoms are exactly the same. Bulb remains stiff during the bogging. Fuel filter bowl on engine reamains 3/4 full during bogging. The engine idles smoothly and will run fine above 4500 and revs to 5400 rpm. It accelerates smoothly and has gobs of power but will not remain at a set RPM below 4500. It has the little electric pump for priming and I believe it is not functioning as cold starts are rough but after warming, engine idles fine. Could the electric pump be the cause of the mid range issue? I have eliminated fuel quality and delivery to the fuel filter as an issue. I even removed the check valve between the carbs and the fuel filter but no difference. I have read other posts and no one has been familiar with the electric prime, manual pump system enough to make suggestions. Any ideas? Before spend the 200.00 for the pump and regulator, can someone verify if this supplies the fuel system other than for cold starts? The Clymer manual is useless. The manual did state that Yamaha has found that the fuel lines could be kinked on this model and result in top end loss of RPM, but this does not fit that pattern as the 92 Aquasport 215 WA will travel 45mph at WOT. Any help would be appreciated.
