I'm new to the motor and trying to figure this out. I have the yellow flush adapter for the lower unit. When I run the motor with this attached it takes a long time for water to come out the pee hole and it is very hot. I feel if I let it run long enough to get a good flush the motor will overheat. When the adapter is attached most of the water seems to come out from around the adapter and not up in the motor. I'm I doing something wrong or is this a common problem?
