I'm looking for help on a '92 225. It has 400 hours on it and is kept in good shape. It idles fine, acceleration with torque starts to bog down with a pinging sound and sometimes it dies. Once I get past that, full throttle is fine. I never had an issue until the ethanol came along. What I am understanding is that I should rebuild my carbs because the mid-range jets are probably clogged. A mechanic showed me several carbourator bowls that he had in the shop that were actually eaten away from the ethanol.
Do you have any info or suggestions?
Thank you
Thank you
