Hey to all newbie here!. I have a 2005 Skeeter Z22 Bay with a 225 v-max. Tonight I was Running the engine with engine muffs and got a temp alarm after about 10 mins of idle. Is this normal? Will the muffs not provide enough water to keep engine cool? I had a great stream from side of motor and good flow through exhaust. I shut down engine instantly and let water continue to run for about 10 mins. Have I hurt my engine?
2005 VMAX225 qUESTION
They will overheat on water hose, can't get enough water. Engine is probably ok.
Before you make any plans to be out for the day, or a fishing trip, check it out. Twice I tried to run my F225 on muffs, and twice I cooked the water pumps, I have since picked up a tank. never again on the muffs for me, too expensive.
Dennis
I cooked an impeller housing on the muffs on my 225 also. I couldn't get it to take a prime. It never did get water out of the indicator though. I replaced the impeller, and the metal and plastic parts of the housing. I used a piece of glass and some course lapping compound to flatten out the bottom of the housings and now I don't have a problem getting the pump to prime.
ÂÂ
