Hi All
New here I have a problem with my Yam28 AE. I was not getting full F throttle, but after tilting the engine to clean the telltail port the engine runns fine with bothfull F and R throttle. Could this be a cable problem and I have moved somthing when the engine was tilted?. I went out again later and had the same no Full F throttle. When in Neutral I seem to get both full throttle in F and R.
Is there anyway of adjusting the throttle and gear change cables? its a single control throttle with the button to disengage the gears.
Any comments or suggestions welcome
Thanks in advance
Rob
P.S any idea where i can get a manual for this engine?
Thanks in advance
Rob
