Last week, I was in Michigan;s Upper Penninsula. On a chain of lakes, I traveled at idle speed over a shallow spot. Seeing that I was going to ground, I went into reverse and backed up. That was the last time that the reverse worked. The motor was tilted up when I did this and did not panic rev it into reverse. It is possible that the prop hit bottom while in reverse, but I do not know. I tried manually moving the linkage with the cable disconnected, but it stops about 1/2 inch before it reaches the back of the greased track that the cable terminal rests in. Forward and neutral are no problem.
Also of note, there is now some movement in the enitre upper cover and powerhead cowling. I see no movement on the transom castings or tilt pivots. Is it possible that a motor mount bushing went and it is causing some misalignment with the the shifting rod to the lower unit? If so, where are those things located? I have looked on the diagrams on the parts section of this site.
If this looks to be something that is going to take some shop work, can anyone recommend repair facility near Kalamazoo, Michigan?
