Oil Sensor Short
  • Oil Sensor Short
    I have twin 1995 200's. In the last month have had 3 oil sensor gauges short out. The engine is running fine. I have replaced the pump and in-line filter. The emergency switch works fine and the sensor in the resevior on the engine works fine. Recently I just by passed the tank sensor and everything works fine. Any idea why the sensor was shorting out????
    The sensors in oil tank in boat don't usually give much trouble but the wire harness going to tank does, corrosion problems cause harness to go bad.
