200hpdi throttle linkage adjustment
  • 200hpdi throttle linkage adjustment
    The screw on the center of the intake linkage to the throttle cam was loose. What is the propper proceedure on adjusting the intake linkage with the t.p.i. sensor??? Any help is greatly appreciated....
    Thank you...
    Sync throttle plates,TPS and oil link arm as per service manual. Adjust idle stop screw until TPS is set at .62 volts.
