200 h.p.d.i. high pressure pump..
  • 200 h.p.d.i. high pressure pump..
    My high pressure side only reaches 100 to 250 p.s.i. after replacing all filters..
    1) Is there a rebuild kit??
    2) If not, do I need to purchase the entire pump or just a certain part of it???
    Any help will be greatly appreciated....
    Thank you.....
    You need to remove and determine what is damaged. The valve is replaced as a complete unit but you can some parts for the camshaft assy, it's usually better to replace camshaft assy as an assemble.
