Oil Element Change with Oil Change?
  • Oil Element Change with Oil Change?
    I have a '03 F9.9.
    Owner's manual does not address changing the oil cleaner element when changing the oil.
    However I see that it is a replaceable item in the parts catalogue.
    Is it part of the normal maintenance procedure?
    Many Thanx
    You can remove and clean the filter on the F9.9, replace it real dirty.
