Any way to bleed trim on 89 200 in the water?
Bleed power trim
Tilt up all the way, top off trim fluid, loosen manual tilt screw on side and allow motor fall all the way down, raise motor by hand all the way to top and recheck fluid. Repeat twice.
Then you have trim motor up and let sit for 15-20 minutes to allow air to separate from oil, trim down and let sit and so on.
ÂÂÂÂÂ
