Multifunction kit
  • Multifunction kit
    What parts not included in the kit do I need to install the Single engine 2 gauge tach speen/fuel managment kit to an 06 vmax?
    Also do you sell a flush kit for the lower unit with low water pickups?
    If you are ordering 6YR-WE035-J0-00 Multifunction Tach and Speed/Fuel combo gauge kit(2005 and newer motors) it has everything needed to install.
    There is an optional lead for GPS connection, it's 6Y5-85721-F0-00.
      do you guys have the 06 yamaha rigging manual in stock? What it the PN? And do you sell a flush for the Vmax low water intake lower unit.
        No we don't sell the rigging manual.
        MAR-FLUSH-ER-VZ Flusher for Vmax
          I've got the tach and fuel speed 2 gauge kit, but I think I am missing some of the wiring harnesses. I've got 3 harneses, the lead that goes between the two hubs, the power harness that has 1 black and 1 yellow wire. And I am not sure where the last one goes, it has a + white wire, a - blue wire, two black wires, a pink wire with a black stripe, and a solid pink wire. I am missing the harnesses that connect the gauges to the front hub, and the harness that connects the hub to the motor. Do you sell these harnesses?
            You have the Command Link Guages which is a different setup, it will work on 2006 HPDI models if thats what you have. The kit does not come with main bus wire or pigtail bus wires for each gauge,it does come with 1 12ft bus wire to go between engine and stern hub, they are available in different lengths:
            MAIN BUS WIRES(need 1 to go between stern hub and console hub)
            6Y8-82553-01-00 1ft
            6Y8-82553-50-00 10ft
            6Y8-82553-11-00 15ft
            6Y8-82553-21-00 20ft
            6Y8-82553-31-00 25ft
            6Y8-82553-41-00 30ft
            PIGTAIL BUS WIRES( need 1 per gauge)
            6Y8-82521-01-00 1ft
            6Y8-82521-11-00 2ft
            6Y8-82521-21-00 3ft
            6Y8-82521-31-00 6ft
            6Y8-82521-41-00 9ft
            6Y8-82521-51-00 12ft
            OPTIONAL WATER PRESSURE KIT
            60V-8A4L1-01-00 HPDI, F50-F115
              Thanks for the help. I ordered the parts from you yesterday.
