When running both engines at about 2900 rpm and when i trim the boat bow up i get two warning buzzers one from each engine both at the same time but no warning lights come on only the buzzers, and i get no RPM reduction on either engine that an overheat would cause. And when turning the key on for each engine i get the buzzer and the arrows above the red, yellow and green lights come on showing they test OK.
Once i bring the throttles down and the boat levels out the buzzers sound for about a minute and than stop, both at the same time. I have good water flow, both from the telltale stream and indicated by 15 - 20 psi water pressure on each engine and the water inlets are clear. The oil tank on each engine is full, but both of my remote tanks are each between 1/4 and 1/3 full.
Could the bow up position have the remote oil tank sensors turn on the buzzers, by sensing a low level? And it is strange that both buzzers come on at the same time and go off at the same time. This one has me stumped for sure!
