Hi Guys,
I borrowed my buddies boat yesterday to go fishing, and it started off ok. We got her in the water and took off. For the first few minutes, it was running pretty rough, but we were still running around 40mph...I figured it would need to warm up before we got up to 60. Anyway, it never warmed up. As a matter of fact it got worse. the rpm's wouldn't go above 2500, and we couldn't get on plane anymore. Bass boat turned trawler. [img]smile.gif[/img]
I want to say this has happened before. Last time, i think he cleaned the carbs and that fixed the problem. Does that sound likely? It has sat for a few months without use, but i didn't thinkt hat would be a problem. It was also last years gas at the bottom of the tank, but i put in all new fuel before we went...
On the way back to the trailer, it got worse...it would only run at like 1200 rpm, and then occationally lurch to 2000, but the right back down.
any ideas? should we just start with the carbs and go from there?
Thanks a lot!
Scott Colba
Bloomington, IL
Thanks a lot!
Scott Colba
Bloomington, IL
