Have a 1999 90 hp jet (90TJRX) that all of a sudden lost power in the hole - can't get it on a plane anymore. Have had the boat for three years, ran Seafoam in fuel every other tank. I've rebuilt the carbs, fuel pump, completely redid the fuel from tank to carbs, compression tested. It holds cylinder head compression. New plugs, new black box, new jet sleeve, new water pump impeller, oil injector working perfect, done pretty much everything I can think of. Lots of $$ also spent at 5 star shop and no fix yet. Hit the throttle, motor hits 58 then drops to 45 immediately. Hot, cold, doesn't matter. Also have all the mechanics in town stumped.
Heard that the Alaska guides that have this motor disconnect the rev limiter and that might help, but don't know which wires to disconnect - yellow/white or pink/white. Any ideas?
Am at wits end trying to figure this out and could desperately use any help.
Thanks!
Jon
Thanks!
Jon
