I have a 150 and had not started it in a couple of months. decided to go out and primed up the motor with the prime ball and fired right up. Now i do have the gauges that comes with this motor and they are all hooked up except the oil sensor. i add the oil straight to the gas tank at a 50:1 ratio. Now the alarm went off when I looked back and saw that it was not peeing. i turn the motor off and checked to see if the hose was clogged and fired it back up. the buzzer continue to go off and had a loss of power. I changed the impeller about 3 yrs. ago. and it has very low hrs on it at all. Overheating problem ? When I get home today, I'm going to try and fire it back up and see if the alarm continues to sound. It was peeing strong until this happen. Any help would be greatly appreciated.
1988 yamaha 150 2 stroke alarm goes off
