New Motor break in time
  • New Motor break in time
    What is the break in time for a new 50TLR
    General Engine Break-in Key Points
    - All Models
    Proper engine break-in can increase the life of
    any engine. The Yamaha Engine Break-in
    Procedure is designed to maintain engine
    component temperatures within an acceptable
    range to provide the best engine life expectancy.
    The detailed engine break-in procedure is
    explained in the Owner's Manual for each
    engine. Some key points are as follows:
    Use 50:1 premix with oil injected models for
    the first 10 hours of operation. (25:l for premix
    models.)
    . Let the engine idle for the first 10 minutes of
    operation.
    Do not exceed 1/2 throttle (3000 rpm) for the
    next 50 minutes.
    DO NOT ATTEMPT PLANING
    WITH A LARGE HEAVY BOAT.
    Second hour
    - Accelerate at full throttle onto
    plane and reduce the throttle to 3/4 throttle
    (4000 rpm). Allow about 10 minutes at 3/4
    throttle for engine to cool internally. Vary
    engine speed occasionally. Occasionally run
    the engine at full throttle for short periods of
    one minute each. Again, allow engine to cool
    after each full throttle operation.
    Third to tenth hour
    - Avoid operating at full
    throttle for more than 5 minutes at a time.
    Allow the engine to cool after each full throttle
    operation, varying engine speed occasionally.
    For the S225V
    & S250V EFI models,
    avoid operating the engine at 2000 rpm
    or below for more than one hour at a time.
    After 10 hours
    - Operate the engine normally.
    Use only straight gasoline for oil injection
    models and premix (with the specified ratio)
    for other engine models.
    Additional points:
    DO NOT RUN THE ENGINE IN NEUTRAL
    FOR EXTENDED PERIODS. In neutral,
    there is no load on the engine. Because of
    this, some internal parts (e.g., the pistons)
    will tend to move in a different pattern than
    normal. This may result in parts wearing
    incorrectly.
    FOR S225V
    & S250V EFI MODELS, DO
    NOT RUN THE ENGINE FOR MORE THAN
    ONE HOUR BELOW 2000 RPM (EVEN IN
    GEAR). During break in, with both premix
    fuel and oil injection, there will be excessive
    oil below 2000 rpm. This excess oil will interfere
    with proper oxygen sensor operation.
