I have a pull to open 703 control with a 7 pin harness. My motor is an 89 40hp (40HEO) with a 10 pin connector. Can I rewire my control to a 10pin cable set to work with this motor. The motor does not have trim/tilt.
Rewire 703 control?
You could replace main harness in 703, the only difference between 7 pin 10 pin is the trim switch wires.
Thank you for your quick reply. I checked your site and found this # (688-8258A-50-00). Can you confirm which part # I will need?
The 10 pin harness for 703 is part number 688-8258A-20-00
ÂÂÂÂÂÂÂ
