Good morning.
I am planning to install a Yamaha FMM on my boat with 2003 twin Honda 200. My questions are:
1. Can fuel flow senders be installed before fuel filters? I believe Yamaha recommends them to be installed between fuel filter and primer bulb/motor. What is the down side of installing them before the filters?
2. My Honda's are fuel injected...I have read from another forum that Yamaha FMM does not handle fuel injected motors well. Is this true?
3. On the fuel flow sender side of the wire harness, I see 2 other terminals. One is black wire and the other is red/white. I assume the black wire is for ground but what is the red/white for? Are these both for fuel sensor/indicator for the fuel tank? If I am not using this function, what is the best way to water proof these extra wires on the harness?
4. Lastly, I have a Furuno Navnet GPS unit. Is this compatible with the fuel managment meter to be connected? It requires NMEA 0183 output from a GPS unit. Where is this output source on Furuno GPS? Where is the best place to get this signal lead for GPS (6Y5-85721-F0)?
Thanks in advance for your time.
Regards,
yhc
Regards,
yhc
