Lost Key as well..
  • Lost Key as well..
    Along with my other problems.. I am keyless. It's a fairly new Yamaha ignition switch in a yamaha con*****er. Is there a number on the switch somewhere that will cross to a key number?? Thanks in advance!
    JoeC
    remove the outer plastic nut on the switch to show number.
      Where exactly is that number for the key?
      is on the side? I do not see it.
      ED
        It's on the flat side switch barrel under the nut.
