Have F90 with multi function Gauge I change RPM 50 +or- Works Great.My Friend has F150 Wants same setup.Is it possible? Thanks
F150 ***** control
Yes the F90 and F150 use same gauge,6YR-W0035-E2-00 Multifunction tach kit(will have harness needed to install. The gauge comes preset for four stroke engines.
***** control
Originally posted by boats.net View PostYes the F90 and F150 use same gauge,6YR-W0035-E2-00 Multifunction tach kit(will have harness needed to install. The gauge comes preset for four stroke engines.
If you want Command Link use
6Y8-8350T-01-00 Tach Kit(round)
6Y8-82553-21-00 Main Bus wire, 20ft
6Y8-82521-31-00 Pigtail Bus wire, 6ft
ÂÂÂ
