I just installed a new digital Yamaha speedometer (boat was repowered recently and didn't change it then). The speed is not registering accurately. Up on plane it will register 8 or 10 mph and the gps shows 30 mph. It did register the proper speed the first time out but not since. I changed the speedometer tubing and I am still having the same problem. All of the switches on the back of the gauge are in the right position for mph. Every other function of the gauge is working fine. Any ideas on what could be causing the gauge to not read accurate speed?
Speedometer Problem
The only plastic thing I saw was the little connecter coming from the tubing from the engine (under the cowling). It appeared clear. I did notice small pockets of air in the tubing after running the boat.
ÂÂÂÂÂÂ
