Can you tell me the OEM part number for a 1992 200hp outboard water pump repair kit. Thank you.
water pump kit
1992 Pro P200tlrq
6g5-w0078-a1-00 Water Pump Rep Kit
61a-44311-01-00 Housing,water Pump
1992 200txrq
61a-w0078-a3-00 Water Pump Rep Kit
OK, thank you. I have another question. After I removed the lower unit of my 200 TXRQ and left in standing for awhile in the garage, I noticed that oil was leaking from around the prop and dripping onto the floor. It is not alot of oil just several drips. Can I take the prop off and replace a seal or gasket on the prop shaft?
ÂÂÂÂ
