TPS Test Harness/Rough Idle
  • TPS Test Harness/Rough Idle
    I have a 1999 Yamaha S250TXRX OX66 with a rough idle and would like to check the TPS. However I can't seem to locate a harness P/N YB-06433/90890-06757. I called this site and was told the part number didn't bring anything up and they would call the Yamaha tool dealer but haven't heard anything back yet. Does anyone have one of these and can you tell me if you are essentually just back stabbing the orange and pink wire? Also I replaced the low pressure fuel pumps,plugs, and installed thermostats which had been removed. Better idle but not quite right yet.
    Mr. Davis,
    We do apologize for this inconvenience. I have just contacted you to inform you of the correct part number needed (YB-06857 test harness for $22.50). As a form of our appreciation please use promotion code: boatsnet to receive an additional 10% off of your next order. This is only valid until 12/16/2007.
    Thank you,
    Jessica Ritch
    Boats.Net Manager
    (800) 512-6287 x124
