1991 200 heads
  • 1991 200 heads
    I bought some used heads that seem different than my 1989 heads. They appear to have a stainless insert around each cylinder whereas mine are all aluminum. Part numbers are supposed to be the same.
    Anyone run into this?
    No I haven't the cylinder heads are aluminum.
      So none ever had inserts? Would there be any way you could you pull a new head out of stock to look at for me?
      Also, can these heads be milled a few thousands to get flat?
