Does anybody have the Yamaha file for the round combination speed/fuel gauge? This file (information sheets ) gives information on installation, setup, calibration, etc. I am particularly interested in connecting my GPS to the gauge for a better speed reading.
Digital Gauge
Let me know if you get the GPS connection to work. I hooked mine up last weekend and the results weren't what I expected.
I may have madea a mistake in wiring and I'm going to recheck today--but I sure went slowly and caerfully. The speed didn't register until i ht 5-6 MPH and when I wnet to reset the swithces on the back of the guage --they were already set to GPS so it sems the precious owner had it set that way and ehn they traded boat in it never got set back after the GPS was removed.
By the way, the speedometer function worked fine before I hooked up GPS with the swiches set improperly--to bizarre !!!
The GPS and Speedometer will need to share the same ground in order to work properly, you might try to move the ground wire from speedo to same ground terminal as GPS.
Originally posted by boats.net View PostThe GPS and Speedometer will need to share the same ground in order to work properly, you might try to move the ground wire from speedo to same ground terminal as GPS.
Does it make sense that the guage would work to some dgree with the switches set for GPS and NO gps connected properly?
Will also work on spelling--my last last message was pretty bad--
Originally posted by Freddy View PostBoats.net
I never received the info, could you email it to me
ÂÂÂ
