removing Seals on Yamaha F50??
  • removing Seals on Yamaha F50??
    The oil seal in the lower unit on my 1999 yamaha F50 is leaking and I need to change the seals but I am not to sure how to remove the seal. There are 2 seals back to back that slide on the spline.
    Has anybody change these seals before? if so how did you remove the old ones?
    Do I have to remove the lower casing cap to remove the seals?
    THANKS
    Sturgeon
    Yes the seal housing does need to be removed to replace seals.
      ya thats the bearing carrier with two seals:
