Dues this look normal??
  • Dues this look normal??
    Just hooked up my computer to the engine and this is what I got. Looks like it is alitle hot?? What do you guys think??
    Thx in advance,
    Larry
    Engine Monitor
    Monitor Item Result Unit
    Engine speed 0 r/min
    Intake pressure 100.15 kPa
    Intake pressure 29.65 inHg
    Atmospheric pressure 1001.5 hPa
    Atmospheric pressure 29.6 inHg
    Battery voltage (12-16) 13.1 V
    TPS voltage (0.5-4.5) 0.679 V
    Throttle valve opening (-1-90) -0.5 deg
    Fuel injection duration 0 ms
    Ignition timing - deg
    ISC valve opening 67 %
    Engine temperature (below 120) 69.5 °C
    Engine temperature (below 248) 157 °F
    Intake temperature (below 70) 29 °C
    Intake temperature (below 158) 84 °F
    Oil pressure (below 842) 61.3 kPa
    Oil pressure (below 122) 8.9 psi
    Engine stop lanyard switch OFF
    Shift position switch ON
    Dual engine system switch OFF
    Shift cut-off switch OFF
    Overheat thermoswitch ON
    Data Logger[Data comparison graph]
    Engine speed[r/min] Battery voltage (12-16)[V] TPS voltage (0.5-4.5)[V] Engine temperature (below 120)[°C] Intake pressure[kPa] Oil pressure (below 842)[kPa]
    1100 14 0.84 69 89.8 780
    1200 14 0.88 68 88.8 780
    1050 13.5 0.8 68 89.3 780
    750 13.5 0.66 69 83.9 780
    700 13 0.66 72 83.4 780
    700 14 0.66 69 80.9 780
    750 14 0.66 68 84.4 780
    650 13 0.66 56 76.5 780
    900 13.5 0.66 58 90.8 780
    900 13.5 0.66 61 85.9 780
    650 13 0.66 52 83.4 60
    950 14 0.66 54 78 60
    900 14 0.66 58 79.5 60
    157 degrees is not hot, not even hot enough to open thermostats but the overheat switch is on. What engine is this?
      f200txra, also found out today that I have 0 compression in Cylinder 1. Also just purchased a new #3 Cam, and rebuilt this engine this week. I was thinking that the 0 compression could be do to miss aligned Timing belt and not checking the valve gap.
      Larry
