Hi,
I have a 2002 200 EFI V-max that is bleeding down from both tilt and trim. Rate is about 5 minutes from level to all the way down. Fluid level and quality is fine. There is no external fluid being leaked.
I'm guessing that there is a bad valve/seal in the gear pump assembly. Rather than replace every valve/seal in this assembly, is there one likely culprit to my problem?
Here's an exploded view of my gear pump.
http://www.boats.net/parts/search/Ya...202/index.html
Thanks in advance.
Thanks in advance.
